  • SN95 4.6L Mustang Tech
lowering do's and donts
  • Thread starter Thread starter Ruckus46Gt
  • Start date Start date Jan 29, 2004
Ruckus46Gt
385
Long Island
Jan 29, 2004
  • Jan 29, 2004
I am doing 4.10's, h&r ss springs, strange shocks/struts, steeda full length subframe connectors all at once is this a good idea? should i save up and do upper and lower control arms? does it matter if i just do lower control arms and not uppers? should i also to steeda ball joints, strut tower brace, g-trac bar, and rear sway bar at once with everything else? any of these a waste of money?
02blackvertGT
Oxnard, CA
Jan 29, 2004
  • Jan 29, 2004
Subscribing...
T
Torinalth
952
Clayton NC
Jan 29, 2004
  • Jan 29, 2004
I've been doing a lot of research on suspension in the past months, from what little i have gleaned doing all at once will just give that much more of an impact when done. as far as the upper and lower control arms, its yourr call..... where do you want to go with the mustang? I personally am doing coilovers, subframes, torque arm, road race lower control arms, pan hard bar, and calling it quits on suspension.
I'm going all maximum motorsports for all this. I just like the idea of a company completely dedicated to mustang suspension... just gives me a better feel then an all around mustang company like steeda. that and I've never heard of an unhappy MM customer. if you get the lower control arms, pan hard, and torque arm bars, with full length subframes you will not have a need for upper control arms, and would have the best possible rear end suspension. hope i have passed on some good info for you to ponder.
Torinalth
KaPPaBaLL
1,326
BAYAREA
Jan 30, 2004
  • Jan 30, 2004
yes, what are you doing with your mustang? the gears, springs, struts, and SFC are a great start. I would do UCA/LCA next. If you're just dragging your car you don't need a STB, gtrac bar or rear sway. Get a panhard bar and torque arm instead. Looks like you're going to need C/C plates as well..
Ruckus46Gt
385
Long Island
Jan 31, 2004
  • Jan 31, 2004
i'm going to be doing a little of everything(some drag,some track)
KaPPaBaLL
1,326
BAYAREA
Jan 31, 2004
  • Jan 31, 2004
a all-purpose racer basically right? hehhe, i know. LCA and UCA's are definitely in your future then. STB and g-trac bar doesn't hurt but rather spend the cash on a panhard bar. Like i said, looks like you're going to need c/c plates. good luck.
Avenger
1,030
QC
Jan 31, 2004
  • Jan 31, 2004
I talked with a guy at Steeda that told me the bumpsteer kit and X2 balljoints are more important than the C/C plates when lowering the car with Steeda Sport springs. I can see why, considering the drop ain't that agressive.
KaPPaBaLL
1,326
BAYAREA
Jan 31, 2004
  • Jan 31, 2004
he's not getting steeda sport springs...
C
CottonBurnerz
Banned
May 10, 2003
1,554
Drink and Drive = Teh Lose
Jan 31, 2004
  • Jan 31, 2004
If I go with eibach pro-kit + tokico 5-way shocks/struts + MM C/C plates, would the bumpsteer kit and X2 balljoint be necessary at all?
K
Ken01GTvert
175
Colorado
Jan 31, 2004
#10
  • Jan 31, 2004
  • #10
If you're planning to do the springs and shocks at the same time and you have the extra cash then I'd go ahead and do the UCA's and LCA's at the same time since you'll have everything taken apart. Even though the UCA's are a PITA I would definitely recommend replacing those as they are real crap stock parts. Replacing both will keep your axle from moving around as much and will help you with either road racing or at the track.
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
