  • SN95 4.6L Mustang Tech
Lowering issues
  • Thread starter Thread starter Doomedfailure
  • Start date Start date Jul 1, 2009
D
Doomedfailure
58
  • Jul 1, 2009
I wish to lower my mustang around two inches. What all do I need to do this properly? Already have the springs, but I dont just wanna throw them on want to be able to align it properly.
VEE EIGHT
85
Texas
Jul 1, 2009
  • Jul 1, 2009
Damn that's quite a drop. You'll most likely need aftermarket C/C plates
J
jlds91389
241
Orange Tx
Jul 1, 2009
  • Jul 1, 2009
ya cc plates are a must with a drop like that. something eles i would look at is aftermarket shocks/struts
Flghtmstr1
572
Springfield, PA
Jul 2, 2009
  • Jul 2, 2009
Why do you want to drop the car that much? I think 1.5 inches in the front is the "sweet spot". Any more than that and you'll scrape everywhere.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 2, 2009
  • Jul 2, 2009
about 1.5" drop in the front and 1.25" drop in the rear is the sweet spot. i had Maximum corner weight my mustang for me and they actually raised it a little bit to optimum.
one thing they were telling me is to add camber bolts as well as the camber plates. that allows you to adjust angles between the upright and the dampener so you can fine tune the suspension further.
9
98_gt_vert_tn
  • Jul 2, 2009
if your goin drop it the full two inchs look and getting full dampeners! they come fully adjustible with easy installation! if you get the right set they will come with all the camber plates! try tein they might not be cheap but by the time you buy all the stuff you need you will be better off! eibach and edlebrock also offer good kits!
ThePumpkin
55
Missouri
Jul 2, 2009
  • Jul 2, 2009
What year is your Mustang?
I had a 2" drop with my Eibach Sportlline springs. Your probably going to scrape on the inside of the front fender (that plastic wheel-well) I had to shave some of it down so I didn't scrape.
Aside from that, I have no problem getting around town. Sometimes my exhaust scrapes, but very rarely. CC plates and a good stiff set of shocks will help a LOT.
You can get by without them for a while, but not for long... the inside of your front tires will dissipate and your stock shocks will go bad pretty quick.
Also, DONT forget to transfer the stock rubber peices from your stock springs (I cant recall what they're called) If you leave them off, your car will drop more than 2".
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jul 2, 2009
  • Jul 2, 2009
MM camber plates are a must with ANY drop
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Jul 2, 2009
  • Jul 2, 2009
x2
You may also want to look into a good set of aftermarket struts and shocks, I prefer tokico
R
Rife96GTconv
73
Sumter, SC
Jul 3, 2009
#10
  • Jul 3, 2009
  • #10
My car is dropped 2" and I would highly recommend getting new shocks/struts and c/c plates. I made the mistake of putting the springs on before the c/c plates and struts, so my recommendation would be to do it all at once, and then take it to get aligned. I went with the MM c/c plates and tokico hp's. The ride and handling improved dramatically once it was all on.
Resolved 2015 ecoboost pp bumpsteer issue
  • matthewt
  • Aug 1, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Aug 3, 2026
fasterthangas
F
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
