  • SN95 4.6L Mustang Tech
lowering springs
  • Thread starter Thread starter Dave0803
  • Start date Start date Jun 14, 2005
Dave0803
236
Leonardtown, MD
Jun 14, 2005
  • Jun 14, 2005
does anyone know of any lowering springs that work with the stock shocks and struts?
9646gt
595
Holloman AFB,NM
Jun 14, 2005
  • Jun 14, 2005
I am pretty sure the Eibach springs work with them..the way I understand is as long as you arent going much over 2.5" you will be fine jsut so long as your struts and such arent worn completely out..also I think dropzone and maxspeed as well as ford themselves make springs for the stock strut
96ninjaman
205
Maryland
Jun 14, 2005
  • Jun 14, 2005
You can use the Eibach ProKit with 1.5" drop with your stock shocks and struts. H&R also has springs with a similar drop. The Ford "C" Springs drop only 1"-1.25", but they all allow use of the stock shocks and struts. With either you should not have to change shocks, struts or CC plates.
9
97gtdroptop
30
  • Jun 14, 2005
Steedas
hotrodnut
672
North Florida
Jun 14, 2005
  • Jun 14, 2005
MRT street springs.
dcarlson
128
Long Island, NY
Jun 14, 2005
  • Jun 14, 2005
Any spring will "work" with the stock struts and shocks, but the stiffer the spring the less the stock strut/shock will be able to damp it properly. The ride quality and handling won't be as good if the shock can't dampen the spring enough. There is no magic point where it suddenly stops working, it is more of a gradual thing as the springs get stiffer and the car gets lower.
Many people run Steeda sport springs with stock struts and have no problem. But the ride quality would definitely improive with a set of Tokico Illuminas.
Some cars need CC plates even right from the factory. Other cars can be lowerd 1.5 inches and not "need" them. There is a lot of variation in the way the cars are built.
pdl2flr
154
Leesburg, VA
Jun 14, 2005
  • Jun 14, 2005
The fact is that the stock struts/shocks are of poor quality when compard to what is available from the aftermarket. You can keep the stock shocks with any lowering springs but you will most likely experience poor performance which will make you dissapointed with the springs.
SilverBullet00
1,150
Wichita, KS
Jun 14, 2005
  • Jun 14, 2005
Very True, I would recommend what I have :
FRPP mach 1 struts and shocks (re-valved tockico HP's)
FRPP "c" Springs
When I bought these I paid 300 for both, Thats only a little more than some of the more expensive springs. One Thing you have to keep in mind though is if you get longtube's down the road dont lower it too much, My springs worked perfect for good header clearence.
BlackenedSVT
1,841
New Jersey
Jun 14, 2005
  • Jun 14, 2005
Dont they all? I know I still ahve my stock shocks on my rear, adn I have Eibach Lowering springs all around.
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Cold Hell,Ontario,Canada!!
Jun 14, 2005
#10
  • Jun 14, 2005
  • #10
All springs work fine with stock struts,and shocks.
I have the eibach sportlines,and ran the stock struts and shocks 2 years in a row,and had ZERO issues on there functionality,aswell as drivability.
I still have the stock shocks in the rear actually.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 14, 2005
#11
  • Jun 14, 2005
  • #11
The stockers suck. As long as you have it apart you should try to change those out as well... You can get kits that have matched shocks/struts and springs. That would be optimal.
Ebay Lowering springs
  • Canyonred86
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
M
Bent Rear Spring Perches
  • Miozu
  • Aug 18, 2025
SN95 4.6L Mustang Tech Sep 8, 2025
PSKSAM2
P
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
Habu135
