  • SN95 4.6L Mustang Tech
Lowering The stang??
  • Thread starter Thread starter 03MGT
  • Start date Start date Jun 21, 2005
1 of 2 Next Last
03MGT
199
  • Jun 21, 2005
Ive had the springs for 2 months now. There for a 2 inch drop.. Ive been chicken about installing them because I read somwere that the driveshaft will rub and such.. Is this true??? What els should I worrie about?? I know ill need cc plates.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 21, 2005
  • Jun 21, 2005
2" is to much in my opinion. I think you should do 1.5" inch or less. With the 2" you may need CC plates and all kinds of new suspension components. Adjustable LCAs to get driveshaft alignment correct. Modified ball joints for new angle. The list goes on and on...
9
97gtdroptop
30
  • Jun 21, 2005
Dont go 2"!!!!Its too much,youll scrape everything.
M
Mstg05
103
Delaware county, pa
Jun 21, 2005
  • Jun 21, 2005
You'll screw up the u-joints (among many other things that will go bad) if you go too low. Stick to 1.5.
The Diesel
26
  • Jun 21, 2005
Dude dont listen to them, just keep the 2in. springs. Its gonna look badass and handle a bit better too. If things get all ****ty then just upgradeparts as they go out.
So what if it scratches? It makes people look your way lol.
M
Mstg05
103
Delaware county, pa
Jun 22, 2005
  • Jun 22, 2005
I'd hate to see your car. And things like balljoints and u-joints....doesn't matter how many times you upgrade them. Driveshafts NEED an angle to lubriate the bearings. If your going to do a 2 inch drop plan on spending some money to do it right THE FIRST TIME, unlike this yahoo above....
hotdog71
427
Seattle, Eastside
Jun 22, 2005
  • Jun 22, 2005
PLEASE don't turn you PONY into a rice burner
97StallionGT
113
Easley, SC
Jun 22, 2005
  • Jun 22, 2005
+1...stick w/ 1/5"
GDawg
1,469
Nevada
Jun 22, 2005
  • Jun 22, 2005
I have H&R Supersports and I have a 1-3/4" drop in the front (1-1/2" in the rear) and it's almost just a tad too low. I have to creep over every speed bump and I've hit my K-member a few times when I've hit bad dips unexpectingly. I may go back to H&R Sports which is about a 1-1/2" drop (or less cause I have urethane isolators).
D
DCBigpimpin
130
TN
Jun 22, 2005
#10
  • Jun 22, 2005
  • #10
I have the Eibach Prokit and they don't seem to drop low enough. I don't want the ricer/skateboard look. but maybe another 1/4" drop. I was thinking of getting H&R SS springs but I don't want to end up scraping on every little bump in the road.
hognutz
1,940
albany, oregon
Jun 22, 2005
#11
  • Jun 22, 2005
  • #11
Having a car low is not rice. I hate to even use the term rice anymore it gets missused so much on this board.
I wanted my car as low as possible without any negative effects.
What brand are the springs??? I would not just run the $90 2" springs of ebay on my car though. I went with the H&R supersports. that was the lowest drop performance oreinted spring I coudl find.
my car does not scrape or run on anything. I do have 1" taller than stock tires as I did not want to have a shorter sidewall than stock so that may be helping me a bit.
the downside to running a cheap srping with alot of drop is you can bottom out and scrape.
you need to decide what is most important too you. Some poeple are happy with the 4x4 stance. some people will live with a scraping car if it looks good.
I was right in the middle. I wanted as low as possible without scraping. The SS did that for me but with 18" 45 series tiers I mathmaitcaly am only 1.25 closer to the ground.
03MGT
199
#12
  • Jun 22, 2005
  • #12
Looks like im gonna go with the Ford racing C springs.. Will i even notice a drop with those??
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 22, 2005
#13
  • Jun 22, 2005
  • #13
This page has a nice chart on the drop springs give for various spring types.
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=272
V_Eight
617
ATL
Jun 22, 2005
#14
  • Jun 22, 2005
  • #14
Negative. I would only scrape on big speedbumps in mine, and if you go at an angle, you'd clear every one.
L
lsubadboy
28
#15
  • Jun 22, 2005
  • #15
so if u went with the fms springs what would be a good shock/strut combo to go with that spring
wesl56
83
Tallahassee, FL
Jun 23, 2005
#16
  • Jun 23, 2005
  • #16
some people like to scrape... the only thing that drags on my car is the heatshields on the cats, which i could care less about
and i dont know who told your driveshaft was gonna rub, but that is impossible...
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Jun 23, 2005
#17
  • Jun 23, 2005
  • #17
maybe you'll get lucky one day and "accidentally" lose them!
96ninjaman
205
Maryland
Jun 23, 2005
#18
  • Jun 23, 2005
  • #18
If you install new urethane isolators the drop will be a little less than 2". It seems to vary from car to car, but in most cases you will need CC plates with a 2" drop. It's also highly recommended to get new shocks with a 2" drop.
I hate the 4x4 look, but I don't want the added expense of shocks and CC plates if I don't have to. Therefore, I'm going with the H&R Sports this time. They seem to settle in a little lower than the Eibach Pro-Kit.
9
97gtdroptop
30
#19
  • Jun 23, 2005
  • #19
I disagree.When I dropped mine 2" I would drive down the freeway and hit a dip going 65,it would defiantely scrape.Thats just my experience.
hognutz
1,940
albany, oregon
Jun 23, 2005
#20
  • Jun 23, 2005
  • #20
Scraped or tires rubbed?
there is no way scraping would occure on a freeway drive a 2" drop unless something is altered.
1 of 2 Next Last
N
SOLD FOR SALE: H&R Super Sport FRONT springs only, 79-93 Mustang, 51650.77 F
  • nfilut43
  • Nov 2, 2026
  • Suspension Parts
Suspension Parts Tuesday at 5:33 AM
nfilut43
N
D
2006 Roush Stage 2 Mustang Chin Spoiler/Lower Grill Inserts Needed
  • DG_Damn_Good
  • Oct 13, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 14, 2026
DG_Damn_Good
D
  • Gulftown980x
  • Jul 29, 2026
squeak93
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
