  • 2005 - 2009 Specific Tech
lowers without the uppers?
  • Thread starter Thread starter xtweakerx
  • Start date Start date Dec 3, 2007
xtweakerx
411
Jupiter,FL
Dec 3, 2007
  • Dec 3, 2007
would i be fine running steeda lowers w/ out the uppers?
radials + intake + tune, + some day gears.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Dec 3, 2007
  • Dec 3, 2007
as long as you dont need to adjust pinion angle for anything, yes. the lowers will help out traction. adding an UCA (there is only one) will add more benefit, but you wont be hurting anything by not upgrading it at the same time. i have not upgraded my UCA yet.
xtweakerx
411
Jupiter,FL
Dec 3, 2007
  • Dec 3, 2007
Nice, steeda told me if they do the lower control arm install and they see the pinon angle needs adjusting they would just do it for me
walter
1,054
Houston TX
Dec 3, 2007
  • Dec 3, 2007
good question I was pondering getting the billet steeda LCA and I was wondering about the importance of swapping the UCA as well. I think I'll mess with that later if at all.
Casey4s
147
Woodbridge, VA
Dec 3, 2007
  • Dec 3, 2007
I did all adjustable upper and lower with BMR tublar arms.
J
jack1.1
78
St. Louis, Missouri
Dec 5, 2007
  • Dec 5, 2007
I just got done with $2100 worth of suspension stuff (roush kit, LCA's). I think the upper control arm is a race only thing.
I doubt if you would need it on the street.
If your lowered and have a street strip car or a track car you may want to look into it for launch adjustment, but you'd probably be better ahead with other suspension mods before you got to this step, if you are racing.
For a street car in my opinion the upper control arm falls under the "not needed" catagory.
Jack
walter
1,054
Houston TX
Dec 5, 2007
  • Dec 5, 2007
Jack
That's what I was thinking too. I think i'll save up for some Nice steeda billet LCA's and call it a day.
If there is one thing I learned from owning my 240SX it was that you really don't need adjustable stuff. I had a fully adjustable suspension setup which cost quite a bit and in the end after I took the car to the track once or twice and found a good setup I never touched it since. If you do homework and get non adjustable parts that give you the ride/handling you want you can save yourself some serious cash and not have to worry about tightening/adjusting anything every x amount of miles.
Resolved Three way cat converters..?
  • PonyGTrider
  • Nov 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2025
PonyGTrider
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
95-early 97 Explorer upper and lower intake manifold - NO LONGER NEEDED
  • R82148V
  • Jul 11, 2025
  • Want to Buy
Want to Buy Oct 31, 2025
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
