LSC Mark VIII elec fan, anyone running one?
Do a search - it's one of the most commonly retrofitted E-fans out there. You will find internet articles with pictures regarding how to do the retrofit and mount it up.
The biggest issue for most is having enough room for the shroud's depth.
Good luck.
+1 on Hissin50
They can be trimmed down quite a bit and mounting tabs riveted top and bottom to install. You may also need to move your radiator closer to the support for clearance. A 3g and a DCController are necessary in my opinion. Thats how mine was done and it works flawlessly.
+1 on Hissin50
Exactly what I did with one difference - I just took a cutoff whell and cut slots in the bottom of the trimmed shroud to use the stock clips on the bottom.
