Overrated install.
It's not that some of us make it seem easy, it's that some make it so hard.
Turning wrenches for a living I have learned that sometimes doing more work equalls less work. It's all nuts and bolts, if it's in your way, remove it. Since your going with o/r stuff, delete all that smog crap and all the tubing, including that crap going to the back of the heads. Take out the airtube and MAF, remove the motormount to K-frame bolt on both sides, lift the motor as far as you can w/o crushing anything and drop in from the top. Maby remove the spark plugs and rock the motor to the side, bam your in. Take the steering shaft from the knuckle on the rack, move it to the side and with the motor up and shifted drop in the other side.
If I was near you I would throw those in for you, it's no biggie.
