  • 2.3L (N/A & Turbo) Tech
lube question
  • Thread starter Thread starter snake109
  • Start date Start date Apr 16, 2006
snake109
60
Austin TX
Apr 16, 2006
  • Apr 16, 2006
a couple of noob question. whats the "best" mineral oil? castrol gtx? and are the suspension/ body bushings and ball joints on these cars greasable? thanks
rd
3,316
63
109
Ocean Springs MS
Apr 17, 2006
  • Apr 17, 2006
I have used Valvoline for the past 20 years with no known problems. Currently, I have tried Motorcraft blend in my stuff, especially where a 5w30 is called for.
The original tie rod ends and ball joints are usually not greasable. Most of the replacements are.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Apr 18, 2006
  • Apr 18, 2006
Just about all of the name brands and most of the off-brand oils are good. I usually use Chevron.
Right. Most of the bushings have to be disassembled in order to grease them also.
R
RustBucket
585
Buford, GA
Apr 18, 2006
  • Apr 18, 2006
I've also been using Valvoline for a number of years with excellent results. I can also attest to the quality of the Motorcraft blends especially the 5w30. The motor in my Mustang was spotless inside other than typical oil varnish when I pulled it apart at 168,000 mi. It had been fed a steady diet of Motorcraft 5w30. If that damned rubber pan gasket hadn't deteriorated and plugged the oil pickup I'd never have had to pull it apart.
Stinger
7,754
24
118
Basehor (Kansas City), KS
Apr 18, 2006
  • Apr 18, 2006
Valvoline or Mobil 1...
Ball Joints Question
  • 93gtmustang
  • Aug 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2025
AeroCoupe
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
G
Front Sway bar HELP
  • Grabberblueguy77
  • May 28, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 28, 2025
gkomo
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
