Lug nut stud install
  • Thread starter Thread starter boxcarracer89
  • Start date Start date Apr 6, 2011
boxcarracer89
153
I live in Roswell NM
Apr 6, 2011
  • Apr 6, 2011
I have a 92 mustang 4 lug, and I broke 2 lug nut studs and got them out, now I am having trouble installing the new ones. I tried putting the lug nut on w a few washers on the stud and tighten them as much as I could, but it still seemed like it needed to pull through more. any suggestions?
This was as much as I was able to pull it through.
2000xp8
SN Certified Technician
Aug 8, 2003
8,071
1,655
194
NJ
Apr 6, 2011
  • Apr 6, 2011
I believe they are supposed to be pressed in by a hydraulic press or equivalent.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 6, 2011
  • Apr 6, 2011
A heavy duty air hammer works well. I am not talking about the cheapo short stroke stuff, but an industrial quality long stroke Sioux or Chicago Pneumatic unit. Otherwise, use washers and lots of lube on the stud and threads and go at it with a heavy duty impact wrench.
boxcarracer89
153
Apr 6, 2011
  • Apr 6, 2011
Damn, Im out of town, Ill have to take off the rotor and have them pressed in, thanks though!!
boxcarracer89
153
Apr 6, 2011
  • Apr 6, 2011
Would u guys happen to know the size to the bolt on the rotor? I just have my small tool set I car in the back of the car and it only goes up to 1in and 27mm. thanks!
capri debris
289
PA
Apr 6, 2011
  • Apr 6, 2011
I always use a block of wood with a hole drilled in it and put the rotor face down with the stud inside the hole... then use a large drift and hammer to pound them in one at a time from the back side.
I use this method with the rotors and the axles... works like a charm... just don't let it get off level on the block of wood or you could distort the rotor.
darthcual
985
Arlington, TX
Apr 7, 2011
  • Apr 7, 2011
Take the top off of the lug so it is open and can run down all the way. Put a cheater bar on that pig and crank it down. Just dont re-use that particular lug, get a new one.
Y
YawnY
42
  • Apr 7, 2011
For the hundreds of them I've install I have never used a press. Impact gun, washers, some front end grease and a open topped scrapper lug nut. Tighten till it sets.
boxcarracer89
153
Apr 7, 2011
  • Apr 7, 2011
Ok! thanks! this was the 1st one that broke on me. Thanks for all the input, great advice!!
faststang90
522
baytown texas
Apr 7, 2011
#10
  • Apr 7, 2011
  • #10
i just installed long ones and i got a nut with thick washers and pulled them in with a wrech
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Apr 7, 2011
#11
  • Apr 7, 2011
  • #11
X2, I just use some washers and an old lug nut and wrenched them right in place, I also use some loc-tite on the splines.
boxcarracer89
153
Apr 8, 2011
#12
  • Apr 8, 2011
  • #12
I had took the rotor to the machine shop, and they told me the studs were to big? So I went to Napa and my rotor is off a 4cyl mustang!! The studs are slightly smaller than the 5.0s so I damaged the rotor. Thats why I was having such a hard time pulling the studs through!! I guess the previous owner installed these for whatever reason!! That gave me such a headache! Ill be buying a new rotor now because the studs just fall out of the rotor. Thanks for the help though, I was wondering why I was having such a hard time and you guys were doing it with such ease lol!!
NOTCH_GUY
31
N.E. PHILLY
Apr 8, 2011
#13
  • Apr 8, 2011
  • #13
Use a large drift punch and hammer.. It'll sink right in. Good luck
83GL50
#14
  • Apr 8, 2011
  • #14
It's not ruined.You could have them bore the stud holes out,it wont take much, to the 5.0 size and then install 5.0 studs.It'll be a lot cheaper too.
faststang90
522
baytown texas
Apr 8, 2011
#15
  • Apr 8, 2011
  • #15
i went to a long stud on all 4 wheels and i had to drill out the front to a larger hole. i was told to have the hole about .020 smaller than the lug. i have a big drill press so it was not a problem.
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
