lugnut patterns
  • Thread starter Thread starter Ford4Fun
  • Start date Start date May 9, 2004
F
Ford4Fun
68
Montana
May 9, 2004
  • May 9, 2004
A while back I bought a 9" rear from a friend who was parting out his early 70s f100. It has a 5 on 5.5" (roughly) lug pattern. My car is running a 5 on 4.5" (ruoghly) lug pattern. I am going to be changing the length of the axle to fit under my car, I will have to buy aftermarket axles to fit the narrower housing. Is there anything benificial to the larger pattern?? If so, how tough would it be to convert to the larger pattern on the front??
golf4283
1,253
Orland Park, Illinois
May 9, 2004
  • May 9, 2004
You will need new axles if u want to use any aftermarket rims. that 5.5" pattern won't be able to bolt up to most (all) aftermarket mustang rims becuase its a different spacing. Getting new axles with the 4.5" spacing is probably necessary.
allcarfan
The Answer Man
2,458
North Atlanta
May 9, 2004
  • May 9, 2004
nothing beneficial and to run any ford rims you would need an adapter. When you swap the rear axles, just makes sure they have a 5x4.5" lug pattern
67coupestang
509
  • May 10, 2004
hell as long as you are narrowing and getting new axles swap on the big bearing ends and get the Explorer rear discs. they all run 5x4.5
F
Ford4Fun
68
Montana
May 10, 2004
  • May 10, 2004
thanks for the replies, I was not sure if there was a benifiet for the larger pattern. I didn't remember about the explorer brakes, thanks for that.
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
T
New here, just saying hi.
  • Tank Mechanic
  • Nov 1, 2025
  • The Welcome Wagon
The Welcome Wagon Nov 2, 2025
nickyb
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
