LX Tailpipe install Question - Driver Side
  • Thread starter Thread starter ned911
  • Start date Start date Jan 11, 2010
N
ned911
48
Round Rock, TX
Jan 11, 2010
  • Jan 11, 2010
In the process of install a new exhaust on a 90LX. The passenger tailpipes went in without a problem but the driver side doesn't want to go over the axles. Is there a specific trick or does stuff like wheel and shock need to come off.
Thanks.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jan 11, 2010
  • Jan 11, 2010
It's just a PITA. I don't remember which, but I ended up having to remove one of my upper control arms, to get my tailpipes on.
306notchback
62
Bells, Tx.
Jan 11, 2010
  • Jan 11, 2010
On mine I just jacked the car up, and had to twist the exhaust until it went on, mine are the factory tips.
12Pack
46
CT
Jan 11, 2010
  • Jan 11, 2010
you dont need to take anything off its just a serious PITA like every1 said, try flipping it and turning it it will go over.
87WhiteStang1
182
  • Jan 13, 2010
jack up the car somewhere on the frame so that there is more room between the frame and the axle, take off the wheel and the quad shock and twist it till it goes in.
apollo12
155
port st.lucie fla
Jan 13, 2010
  • Jan 13, 2010
I just did this on one of my Mustangs.Put the rear body(frame) up on jack stands(as high as you can) a good jack in the middle of the rear end,do one side at a time remove the rear bolt of the quad shock,upper control arm bolt on the rear end and the bolt on the shock that connects it to the rear end,then just lower the rear end.It worked for me, good luck
Chrome_Rust
530
Findlay, Ohio
Jan 13, 2010
  • Jan 13, 2010
I popped my shocks...both went in no problem....
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Sound deadener install
  • limp
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
limp
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
