• Community Forums
  • Regional Forums and Event Information
M.A. Inspection Sticker
  • Thread starter Thread starter GREYFOX4INCH
  • Start date Start date Aug 5, 2005
G
GREYFOX4INCH
190
western MA
Aug 5, 2005
  • Aug 5, 2005
last year i got hooked up with a sticker, the car was not inspected. it was the first year i owned the car. does anyone know, do they automaticly do emissions the first year and alternate every other year after that, or dose it depend on the year. i dont know if i was supposed to have emissions done so i dont know if i need it this year. its a 1987
IS THERE ANYONE IN THE WESTERN MASS AREA THAT CAN "INSPECT" MY CAR this is still america isnt it
M
mackey
1,284
Beverly, Massachusetts
Aug 5, 2005
  • Aug 5, 2005
They alternate every year. Best bet would not be post it on the forum that you are looking for a place... Ask around your town... Come in ina friends car and ask the local shops.
G
GREYFOX4INCH
190
western MA
Aug 5, 2005
  • Aug 5, 2005
any of you ever inspected cars before???????
i know it alternates, dose that mean they will assume that emissions was tested last year(first year of registration)and skip it?
or can they tell if it was done.
G
GREYFOX4INCH
190
western MA
Aug 9, 2005
  • Aug 9, 2005
daaaaaaa, anyone?
winks
139
eastern mass
Aug 9, 2005
  • Aug 9, 2005
The rule use to have to do with the year of the car but they changed that.
Now my understanding is as long as nothing changes (same owner and registration etc), you will be emissions tested every other year. If you didn't have it done last year you will need to have it done this year and vice-versa. There may be more complex rules in there that would change things (such as you have been caught removing emission equipment, gross polluter, cheating, etc), but basically that is the idea.
I used to take my stang off the road in the winter and re-register in the spring. Every time inspection came up, my car would be flagged to need an emissions test. If stunk and to me was definitely not fair but there was nothing I could do.
The registry knows when the last time your car was emissions tested, and the inspection station's test equipment is linked to the registry. Since you are a "new" owner of the vehicle, you will show up as needing an emissions test.
G
GREYFOX4INCH
190
western MA
Aug 10, 2005
  • Aug 10, 2005
thanks that helps, im pretty sure im gonna need it this month. but what i wonder is: if i keep getting hooked up every year,say i go 4 years without emissions, can i get away with it? i have no cats,and every peice of emissions equipment deleted.
it was all taken off before i bought the car.
has anyone ever passed with just cats and no smog pump???????????????????????
i have a small cam too, 480 lift
im moving out of this state
ImportEater98
708
Worcester, MA
Aug 10, 2005
  • Aug 10, 2005
Let me clarify this once and for all:
You say you got "hooked up" for a sticker last year which was when you first registered the car, correct? If that is so, than the sticker should say "ES" under the calander month number on the face of the sticker. This stands for "emissions and safty". This year all you should need is a saftey inspection. When you get your new sticker there will just be an "S" under the month number. Basically the first inspection of a newly registered car automatically gets emmissions testing and thats that. You should be in the clear for one more year.
G
GREYFOX4INCH
190
western MA
Aug 10, 2005
  • Aug 10, 2005
under the calender month is my vin,below that is a upc for a scanner.top left is the exp date, on the top right side of the sticker is what apears to be a 5 but could very well be a "S" not "ES". but it looks more like a 5 to me.with my luck it is an "s". how could someone inspect the car for the first time and skip emissions?
it was done at a ford dealer.he just pulled it in, parked it sideways on the rollers and slapped a sticker on it. never even looked at the car. wouldnt the registry know that they never tested it, if it only has an "s" on it?
i gotta go talk to a garage just to ask questions.then go somewhere else for the inspection.
i gotta find out if that kid still works at that place and have him do it again.
G
GOSTEEDA
20
AYER, MASS
Aug 11, 2005
  • Aug 11, 2005
if you have no cats, depending on the people at the shop, they WILL look to see if you car has cats for the safety check
9
90Notch
1,046
Westwood, MA & yes it's killing me that I'm no
Aug 12, 2005
#10
  • Aug 12, 2005
  • #10
S most likely is just safety so you should need emissions this year. Not sure what .480 of lift has anything to do with emissions, its the amount overlap and duration along with condition of motor that dictates the emissions. If this is a B303 you are not going to pass emissions and no one cares that you bought the car this way. Better start buying emissions parts or find someone to hook you up again.
CobraStang95
84
New Jersey
Aug 15, 2005
#11
  • Aug 15, 2005
  • #11
I work at a shop and all I do is inspections- all day everyday. There is a way to bypass emissions but barely anybody knows about it. So if you wanna drive out to eastern mass to my shop, I'll put a sticker on it. Otherwise your gonna have to find somebody that knows how to do it.
M
Paint and Body Restoration prob
  • Magnet86
  • Jul 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 18, 2025
2000xp8
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
  • Community Forums
