Mach 460 6 disc swap completed
How did you hook up a sub to the stock deck? I have a eclipse amp and 12" sub in mine now but im using a nakamichi deck and im thinking of going to the stock 6 disk and mach system
You have to get a speaker level to RCA converter and pick up the signal(s) from the wires that go from the CD6 to the rear MACH460 amps. This is an un-amplified low pass signal which works just fine for a subwoofer.
kovacs22 said:
the wires that arent hooked up (for whatever reason?) are:
on the radio harness which contains the power, illumination and speaker outputs, there is a "RADIO ON OUTPUT" which is OG/LB and the other unconnected wire is a "RADIO ON OUTPUT MUTE" (DB), what do these wires do? im guessing the first one might be power for the amps...but what do i conect it to?
Might "RADIO ON OUTPUT MUTE" (DB) be an input to automatically mute the music like when a cell phone call comes in????? :shrug:
