Mach 460 sound system
808SN95
25
I'm having trouble with my stereo system. There seems to be a background noise like a bad ground. When I accelerate it makes a whining noise. Sometimes it goes aways and then it comes back. Does anyone know how to get rid of it or fix it?
Do you have the stock radio in your car? Check for bent pins in the harness this will also cause some feedback, also if you have an aftermarket radio it could have a loose connection or bad ground as well. Good luck Dan
No I think there is two wires touching or grounding eachother out. This was a problem that came from the factory. Go to the sound and shine forums on stangnet. I think there is a write up of how to fix it.
Dustin
