  • SN95 4.6L Mustang Tech
Mach Audio Replacement
  • Thread starter Thread starter Corrosion
  • Start date Start date Jun 12, 2012
C
Corrosion
  • Jun 12, 2012
I have a 2000 gt coupe with the mach 460 audio system and I want to replace it with an aftermarket receiver. I have pulled the factory deck and hooked up the aftermarket deck with the wiring harness' supplied. The problem is that every wiring harness that I have been able to find does not have a connector for the 6 pin connector. With this being said, I have power to the deck, but no sound because I don't have the six pin connector hooked up. How or where do I wire in the six pin connector? What I have done so far with the wiring is....gray plug to the deck, ant to ant connection, 8 pin to speakers, black ground wire to ground, 6 pin to ?.....HELP!
IcedTea
12
  • Jun 13, 2012
I could be misunderstanding what you are saying but, I believe you need a plug that turns the 6 pin into rcas and then you plug those into your front and rear rca inputs in the back of your receiver. This is so your 460 amps can get signal to run your speakers. Try this http://www.crutchfield.com/p_120705510/Receiver-Wiring-Harness.html?tp=2977
twogts4us
4,188
12
79
Dunedin, FL
Jun 19, 2012
  • Jun 19, 2012
Please take a look at my thread (http://www.stangnet.com/mustang-for...uestion-re-parking-brake.857279/#post-8627552) and help us out with some pics of the back of the radio and the harness you are using.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Door wire harnesses 1996 GT
  • Adizzle843
  • Feb 5, 2026
SN95 4.6L Mustang Tech Feb 17, 2026
Adizzle843
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
