My Fox is already 5 lug, but still has drum brakes in the rear. I want full disc brakes. So instead of piecing mine together, and having to do some tear down and build up. I want to just swap a 5 lug disc brake rear. I found a complete mach1 rear on CL.
From what I can find from searching, it's A direct swap. It's .750" longer each side (1.500" total), and I'll have to make my brake lines. And already has 3.55 gears.
So that's the easy part. I wasn't able to find information about brake caliper piston and rotor size. I do not want the rear brakes over powering the front causing unstability.
Anyone has this info? Or done this swap already and have some advice?
