Machining Costs?
  • Thread starter Thread starter Papageof
  • Start date Start date May 21, 2004
Papageof
322
Jacksonivlle, FL
May 21, 2004
  • May 21, 2004
How much have ya'll spent on preping your short-block for your rebuilds? I was looking to have mine: cleaned, honed/bored, balanced. I don't think it'll need decking or align-honing but who knows till you measure. What do you think that will cost around J-ville, FL. Also, any good recomendations for local machinists?
Papageof
322
Jacksonivlle, FL
May 21, 2004
  • May 21, 2004
ttt
79'293stang
505
11
29
Cedar Rapids, Iowa
May 21, 2004
  • May 21, 2004
i spent about 350 for .030 bore, honing, new freeze plugs and cam bearings and of course the block boil. then about 400 more for my head work, hope that helps.
Ranchero5.0
The Voice of Reason
Jan 1, 1999
5,306
Hagerstown MD
May 21, 2004
  • May 21, 2004
Bore $250
balance $125
redo rods $70 + bolts
Crank $250
Clean and mag $75
more or less.
Jamie
dastang2
2,020
tx
May 22, 2004
  • May 22, 2004
500 with new pistons and pressing them on the rods, valve job on heads, block bored .060 with new cam bearings and freezplugs. plus 60 dollars for turning the crank 10/10 it was also hot tanked and looked brand new
86strokerlx
126
  • May 22, 2004
spent in the neighborhood of $450 for .030" overbore and hone, magnaflux, main bore alignhone, freeze plugs, hot tank and cam bearings of my choosing(bearings and install). i clearanced the block for the stroker kit myself so that saved some money. expect to pay a little more. will be shelling out another $400 or so to have the WHOLE bottom end balanced(pistons, rings, rods, pins, crank, damper, flywheel and clutch). do your research and don't simply go with the cheapest! call and find a place that specializes in SBF's and you'll be glad you did! have them break down the costs. you don't have to get it all done at once if you can't afford it. ask to speak to some of their clientele. if they say no and won't tell you how many engines they do a month, leave. you only want to go thru this process once. TRUST ME. hope this helps. good luck!
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
4K
Classic Mustang Specific Tech Today at 8:14 PM
horse sence
H
1966 mustang starter and pulley troubles
  • Hotrods4ray
  • Sep 24, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
Realmongo
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
