Lightning?, SCT? or Anderson pro 80maf?
Building a new setup for my 95 cobra coupe.
CURRENTLY....
Currently running stock gt40 motor and heads with KB 1500 6 lb pulley. 42 lb injectors anderson motorsport power pipe with anderson ProM 80mm supercharged MAF. With a sct tune, got 331 horse 340 torque at rear.
OVER WINTER....
I have a DSS 306 Pro bullet with AFR 185 heads 61cc. Ordering a FTI custom cam next week. Have a KB 1500 running 8psi, still same 42lb injectors. Compression is just under 9 to 1. Will be running a gt crank pulley so actual boost will be around 8.5 to 9 psi. 255 intank pump, bbk long tube headers, Bassani catback. 70mm throttle body too.
Went to my dyno guy, EJ'S dyno in Omaha "the man" he states that my Anderson Pro-M 80mm supercharged MAF will be pegged if I leave it on. He recommended a 90 lightning or a Big a$$ SCT MAF 2400. I hoping for 450 rwhp out of this setup!
or more
will get tunned with SCT chip.
The car is a multi-purpuse car....show, drag 4 or 5 times a year and autocross occasionally. Not a daily driver but must be street friendly(parades).
With this info in mind, you Kenne bell guys or tuners on here...What would you recommend to support this horsepower safely and why.
Lightning $99
SCT $300
Thanks Purvenm
CURRENTLY....
OVER WINTER....
Lightning $99
SCT $300
Thanks Purvenm
