MAF HELP NEEDED
rickd93_lx
162
i have a quick question, i have a X3z ecm, wich is for 24# injectors., so would i need a mass airflow for the injdectors, or can i use the stock 5.0 maf and would it work with the larger injectors. Just so you know i have a 95 cobra motor i am droping in a 2.3 yr 93, (93 prts car lx 5.0.) Its probably a dumb question but weirder things have happened.
The Cobra computer is internally calibrated for 24 lb injectors. That means you can use the stock 19 LB MAF or any other 19 LB MAF.
I like to use a 94-95 Mustang GT MAF since it is 70 MM, and is a bolt on when you use the duct adapter to mate the flage to the slip on ducting.
so ive seen on e bay vortech maf 80mm for like 5.00 and i can take the sensor off of my 5.0 and install it in the vaortech as it does not have the sensor, do you think 80mm is going overboard?...thanks buy the way.
