maf in fender
stangster50
129
cranston ri
since its so damn cold out all i can do is think of ways to clean up my eng. bay and hide things. i was thinking of placing the maf inside the pass. fender. will this work, or will the increased distence between the tb/shorter distence to fiter screw things up, and cause it to read wrong. if it does change things, is it enough to cause driveability problems?
Maf in the fender isn't new. A lot of people that run CAI's do that because the 90* bend in the tube sometimes distorts the airflow and the MAF gets a wrong reading. I say give it a shot.
Kevin
When you run a powerpipe, do you have to extend the wiring harness for the MAF or will the factory harness reach?
If you have to extend it, do you just cut and splice or does someone make an adapter that extends it?
Yeah. Powerpipe or UPR boost pipe puts it in the fender. As do some other CAI setups. I know it can be pusing the length of the wiring. Just gives you a good excuse to get a Pro-M maf specifying fender mounting which will get you the proper wiring lengths.
