- Aug 1, 2005
- 21
- 0
- 1
Has anyone ever heard of the location/position of an MAF meter causing idle problems?
Here's why I ask. If I start my car up (cold or warm), it fires right up and finds a perfect idle. However, once I'm driving around, when I push the clutch in to slow down, it drops the idle to about 1200 rpm and won't settled until the car comes to a complete stop. It's the oddest thing. I swear the engine knows when the car is is stopped versus rolling. At first I thought it was just coincidental timing of the engine struggling to settle down to an idle and the stopping of the vehicle, but I've tested the theory several different ways... as long as I'm moving/coasting, no matter how long/far, it won't settle to normal idle.
So, trying to make sense of this... the only conclusion I could come to is the MAF is picking up air readings while I'm coasting and causing the computer to think the throttle is open, when it's not. Not sure why the TPS doesn't offset that reading, but maybe the MAF has a higher priority than the TPS if the readings disagree?
Anyway... has anyone heard of anything like this before?
My injection setup is as follows:
Pro M 80mm MAF
Anderson Ford Power Pipe (which locates the MAF down way low in the front fender)
75mm Throttle Body
30# Injectors
(Naturally Aspirated 347)
Pro M 80mm MAF
75mm Throttle Body
30# Injectors
