MAF question...
  • Sponsors(?)
santos
362
52
Camp Hill, PA
ehh, im not here too often, usually when I have a problem and need some help. currently trying to figure out a loss of power, bogging, above 3k. ive replaced all fuel components and ignition components. last resort is the MAF. ordering one this week, hopefully solves my problem.
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,357
2,824
234
74
Dublin GA
lowendmac.com
Dump codes sticky
Look at the top of the 5.0 Tech forum where the sticky threads are posted. One of them is how to dump the computer codes. Codes may be present even if the CEL (Check Engine Light) isn’t on. You don’t need a code reader or scanner – all you need is a paper clip, or if your lady friend has a hair pin, that will do the job.
I highly suggest that you read it and follow the instructions to dump the codes. http://www.stangnet.com/mustang-forums/threads/how-to-pull-codes-from-eec4.889006/
santos
362
52
Camp Hill, PA
thanks Jrichker, ive dumped the codes, all I get are EGR codes, which has been removed. this has been a frustrating problem
jrichker
Mar 10, 2000
27,357
2,824
234
74
Dublin GA
lowendmac.com
High speed miss on a warm engine
Revised 7 Nov-2016 to add PIP sensor as possible problem and dumping the codes to help determine if it is the TFI or PIP.
The TFI module mounted on the distributor is one of the culprits for a high speed miss on a warm engine. The other suspect is the PIP sensor inside the distributor. If the problem does not occur when the engine is cold, the TFI module or PIP is definitely suspect. Dumping the codes may help determine which one it is. You may need a special socket to remove the TFI module, but most auto parts stores will have one for $5-$7.
It is not uncommon that the replacement parts may be defective; TFI modules made by non Ford manufactures seem to have a high failure rate.
Be sure to use plenty of the heat sink grease on the new TFI and clean the old grease off the distributor.
See Automotive Tools Specialty | Auto Mechanic & Technician Diagnostic, Testing Equipment | Thexton
diagram courtesy of Tmoss & Stang&2Birds
santos
362
52
Camp Hill, PA
thanks, both dizzy and TFI are new, same conditions with new parts as old parts, I even swapped them back and forth
Thread starter Similar threads Forum Replies Date
D Engine MAF question for a 4.6 P1SC Procharger SN95 4.6L Mustang Tech 0
1970machwon Engine A couple MAF questions (Finally got my donor engine!) Fox 5.0 Mustang Tech 6
Keith5.0GT Maf mystery question. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
C 94 Mustang Cobra Maf Question 1994 - 1995 Specific Tech 6
E Calibrated Maf Question Fox 5.0 Mustang Tech 11
from6to8 Going To A Slot Style Maf For Na Possibly. Got Some Questions 1994 - 1995 Specific Tech 10
87notcher Electrical Maf Conversion On An 87 W/ 89 Harness Question Fox 5.0 Mustang Tech 15
5 1989 Gt Maf Questions Fox 5.0 Mustang Tech 2
B Engine Throttle Body To Maf Size Question Fox 5.0 Mustang Tech 7
J Throttle Body, Cai, And Maf Question With My 92 Fox 5.0 Mustang Tech 18
master_bayshin C&l/mac Maf Calibration Tube Questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
D Fox Maf Questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 27
BKM48198 94-95 70 Mm Maf Question Fox 5.0 Mustang Tech 35
doobismaximus Maf Question 1994 - 1995 Specific Tech 7
N Quick Maf Question Fox 5.0 Mustang Tech 17
90lxwhite Tuning- Maf Questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
D Engine Question About Maf And Iac Valve Fox 5.0 Mustang Tech 31
J X3z And Cobra Maf Question? Fox 5.0 Mustang Tech 4
John Dirks Jr Maf And Tb Questions Fox 5.0 Mustang Tech 49
8 Maf conversion question Fox 5.0 Mustang Tech 5
Cory Berg Maf Conversion Questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
V Maf Conversion Question Fox 5.0 Mustang Tech 1
RUNINAGT Maf Question Fox 5.0 Mustang Tech 3
K PRO M maf question Fox 5.0 Mustang Tech 5
Cobra Ezra MAF question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
87-t-top-gt maf conversion injector question Fox 5.0 Mustang Tech 2
JasinC19 Question about aftermarket MAF to match 24# injectors Fox 5.0 Mustang Tech 2
Slo5Oh89 MAF Question need your expert advice! Fox 5.0 Mustang Tech 9
superdavestrate MAF question Fox 5.0 Mustang Tech 3
9 05+ MAF question Fox 5.0 Mustang Tech 7
aub02GTconv New MAF sensor question SN95 4.6L Mustang Tech 6
W Maf, injector, sct tune question! SN95 4.6L Mustang Tech 3
NOTCH_GUY MAF Question Fox 5.0 Mustang Tech 8
A MAF conversion question Fox 5.0 Mustang Tech 9
tims 86 MAF SENSOR INTAKE QUESTION Fox 5.0 Mustang Tech 11
95Vert383AOD MAF 4/6 wire question 1994 - 1995 Specific Tech 12
Night Shifter quick question about running injectors w uncalibrated MAF 1996 - 2004 SN95 Mustang -General/Talk- 10
C Stupid MAF conversion question Fox 5.0 Mustang Tech 2
ReplayMan New MAF install question Fox 5.0 Mustang Tech 13
F 93 notch maf to throttle body questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
RsStanG1987 Maf question Fox 5.0 Mustang Tech 19
J MAF Sensor Question.. 1996 - 2004 SN95 Mustang -General/Talk- 0
keepinitril MAF mounting question Fox 5.0 Mustang Tech 1
keepinitril MAF question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
393strokervert have a question creating a MAF transfer with my Pro-M flow sheet Fox 5.0 Mustang Tech 7
sneaky98gt Quick Question about MAF and Injectors 1996 - 2004 SN95 Mustang -General/Talk- 9
bdog9seclx Tuning question and MAF question Fox 5.0 Mustang Tech 2
Brandon11010 techanical maf/injector question/theory Fox 5.0 Mustang Tech 6
79'293stang Granatelli MAF Question. 1994 - 1995 Specific Tech 4
T maf combo question Fox 5.0 Mustang Tech 9
