MAF SENSOR, DIFFERENCE HERE?
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
Someone told me to clean the maf sensor to see if that helps with my problem of car wanting to bog down when 3000 and up rpm, and got a backfire once. So I haven't had a chance to clean it, i just got it new though. But anyways, was checking the numbers on the thing and the stock one read:
F17F-12B5979-AA
AFH55-03B
and had the numbers 1J02 engraved below those sets of numbers
and the 70mm one I got has
F17F-12B5979-AA
AFH55-03B
and has 2F25 engraved below that
Are the numbers correct for what I've got? or did someone just put a different electronic from a stock one onto the 70mm housing?
You need to pull the codes first, this will give you an idea of what the problem could be.
Cleaning the maf is never a bad idea. Most say to use a Q-tip and solvent, but I prefer to spray liberally with brake cleaner because there is no risk of residue or damaging the wire.
