maf signal rtn(ground)has voltage
574stang
10
Indiana
hey guys.My brother and I recently bought a 92 foxbody with an on3 turbo kit. This is a project, we bought it in a no running condition. we just got the car running it will fire up and idle but does not run well at all. we pulled codes and they are very inconsistent. we checked sensors for voltage reference and ground. all sensors seem to be in good order along with the wiring except for the maf. pin 9 on the maf has 5.9 volts. i thought maybe the wire was rubbing through to voltage but after back probing pin 9 at the ecm connector i see that the voltage is coming out of the ecm. i removed the ecm and checked for burnt spots on the computer board and found nothing. what is my next step to troubleshooting this problem? thanks for the help in advance.
What codes did you get?
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
