I have a 97 GT that I am doing the PI swap on. I also have VT stage 1 cams and the C&L upper intake. I would like to put on an upgraded MAF and also a CAI. I am currently running stock injectors and do not plan to upgrade these any time soon.
I am curious what you guys recommend for a MAF. I know there are stock 80mm MAFs out there that I can get but not certain which ones will work with the 97 computer. Also I am not certain 80mm is the way to go with my set up. Need your advice.
Also I am going to add a CAI and 75mm TB. I want to do the CIA, TB and MAF all at once just before I get the engine dyno-tuned. This way it will all be calibrated correctly. Your thoughts?
