  • SN95 4.6L Mustang Tech
Maf?
  • Thread starter Thread starter coreys2k3gt
  • Start date Start date Aug 29, 2005
C
coreys2k3gt
  • Aug 29, 2005
I never really see this thread so out of curiosity any suggestions on maf's? Corey.
M
mac1009
187
Atlanta, GA
Aug 29, 2005
  • Aug 29, 2005
Depends upon your mods, minor bolt-ons will not require you to upgrade your MAF.
sgarlic
3,085
Aug 29, 2005
  • Aug 29, 2005
BLKsteeda
236
Anywhere
Aug 29, 2005
  • Aug 29, 2005
You probably wont need it unless you install a supercharger...I pretty much have every bolt on plus ported heads and cams and it didn't require a new MAF.
Lons2001GT
75
  • Aug 29, 2005
I saw modest gains on the dyno using a c&l maf on my gt when it was n/a. You have to use the c&l inlet pipe too to avoid check engine lights (More flow then stock units). I would expect 5-7 whp.
twogts4us
4,188
12
79
Dunedin, FL
Aug 29, 2005
  • Aug 29, 2005
OEM is good to 400 HP. The C&L MAF uses the stock electronics and is simply a freeier flowing tube that leans the A/F ratio to make power.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 29, 2005
  • Aug 29, 2005
Leave the MAF alone...
Lons2001GT
75
  • Aug 29, 2005
OEM is a good unit and will support 400hp (obviously in a blown car in most cases), but when is more power ever a thumbs down ? My a/f was 12.5:1 when using the c&l meter. I had no tuner and a steeda timing adjuster set at 14*. Most guys that are n/a and don't have the money for a blower setup are looking for every last available hp, and the c&l maf is a way to pick up a few. I understand that bang for the buck, an upgraded maf is not the best mod in the world but it is still a valid option for someone who wants every last hp.
twogts4us
4,188
12
79
Dunedin, FL
Aug 29, 2005
  • Aug 29, 2005
It's just my opinion...C&L MAFs are junk. The make power, but unreliably. You take one of the most delicate electronic pieces in the car and throw the R&D in the garbage. Heck, just look at it. The C&L MAF is nothing more than an expensive cast (it's not even billet) aluminum tube...you could likely use a piece of PVC pipe and get the same effect. Leaning the motor out is a good way to make power and get every little bit you can, but I just think tuning it to do this is a better, more reliable way to do it.
jstreet0204
939
Winston Salem, NC
Aug 29, 2005
#10
  • Aug 29, 2005
  • #10
The problems it can cause are not worth the couple of hp you gain from them.
http://forums.modulardepot.com/showthread.php?threadid=25092&highlight=maf+and+problems
Josh-'96 GT
67
#11
  • Aug 30, 2005
  • #11
Yeah, in Sean Hyland's book he's pretty against aftermarket MAFs. There are OEM Ford MAFs that can deliver increased airflow, if it is really necessary. The Lightning meter (with 42# injectors) will support in excess of 600hp with OEM reliability. Since the range of the meter is tied to the injector size of the original car, you can just change to another Ford meter with a higher airflow range if needed by your combination.
Dan_Soprano
7,410
54
129
Jacksonville, FL
Aug 30, 2005
#12
  • Aug 30, 2005
  • #12
Best aftermarket MAF out rigth now is the SCT Big Air unit, hands down.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
  • Gulftown980x
  • Jul 29, 2026
squeak93
J
High idle 2003 Mach 1
  • JohnnyUtah
  • Mar 29, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
JohnnyUtah
J
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
