- Jul 15, 2005
- 16
- 0
- 0
OEM is a good unit and will support 400hp (obviously in a blown car in most cases), but when is more power ever a thumbs down ? My a/f was 12.5:1 when using the c&l meter. I had no tuner and a steeda timing adjuster set at 14*. Most guys that are n/a and don't have the money for a blower setup are looking for every last available hp, and the c&l maf is a way to pick up a few. I understand that bang for the buck, an upgraded maf is not the best mod in the world but it is still a valid option for someone who wants every last hp.twogts4us said:OEM is good to 400 HP. The C&L MAF uses the stock electronics and is simply a freeier flowing tube that leans the A/F ratio to make power.![]()
It's just my opinion...C&L MAFs are junk. The make power, but unreliably. You take one of the most delicate electronic pieces in the car and throw the R&D in the garbage. Heck, just look at it. The C&L MAF is nothing more than an expensive cast (it's not even billet) aluminum tube...you could likely use a piece of PVC pipe and get the same effect. Leaning the motor out is a good way to make power and get every little bit you can, but I just think tuning it to do this is a better, more reliable way to do it.Lons2001GT said:OEM is a good unit and will support 400hp (obviously in a blown car in most cases), but when is more power ever a thumbs down ? My a/f was 12.5:1 when using the c&l meter. I had no tuner and a steeda timing adjuster set at 14*. Most guys that are n/a and don't have the money for a blower setup are looking for every last available hp, and the c&l maf is a way to pick up a few. I understand that bang for the buck, an upgraded maf is not the best mod in the world but it is still a valid option for someone who wants every last hp.
