  • 1994 - 1995 Specific Tech
MAF's
  • Thread starter Thread starter sage2k
  • Start date Start date Aug 3, 2005
sage2k
645
Baton Rouge, LA
Aug 3, 2005
  • Aug 3, 2005
How can I tell if I have a stock MAF or aftermarket one? After reading an article in a previous thread I think maybe this is why I may have some weak lowend? Previous owner may have put an aftermarket MAF in the car? I dunno and would like to check.
Can I get some more explainations on MAFs, if aftermarket maf's can really screw up timing curves, is the only safe way to get a new maf is to get a custom tune? So if i want to get a h/c/i (trick flow in particular) that would mean a person would also need to upgrade their maf, tb, injectors, and get a custom tune? Im still new and learning before i touch anything
DarkProphet
391
Quakertown, PA
Aug 3, 2005
  • Aug 3, 2005
If its polished its deffinatly an aftermarket. Also my C&l says C&L on the bottom of it you could that too. just a few ideas.
CManT1914
3,172
Killeen, Texas
Aug 3, 2005
  • Aug 3, 2005
The stock MAF will say ford on the housing somewhere I believe. Aftermarket ones will say C&L or Pro-M, usually on the electronics themselves. A quality MAF (Pro-M) will not hurt low-end performance. A crappy MAF (C&L) will f*** everything up. Not saying all C&L's are bad, but mine's a POS and so has everybody else's I know. When doing a decent h/c/i swap, injectors are usually neccessary (unless building a mild combo, like gt-40's etc). You mentioned Trickflow, you'll need bigger injectors for that setup most likely. Of course with injectors comes a new MAF. Can't have one without the other.
sage2k
645
Baton Rouge, LA
Aug 4, 2005
  • Aug 4, 2005
and with a new MAF I'd need a tune, correct? And new fuel pump for the extra power?
illwood
636
Worcester, MA
Aug 4, 2005
  • Aug 4, 2005
Depends on what your other supporting mods are. Are you going to go with a MAF calibrated for 19lb/hr injectors or larger?
If the MAF is calibrated for 19lb/hr (GT stock) you should just be able to swap it in, no problem. If you go here http://fordfuelinjection.com they explain why if you want larger injectors, you should still use a MAF calibrated for stock injectors and then just tune the computer for the larger injectors.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 4, 2005
  • Aug 4, 2005
If you really wanna learn go read this stuff and focus on about the first 1/3 of the info.
http://www.superstang.com/maf.htm
Come on back here and tell me what you think.
Later
Grady
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
