  • SN95 4.6L Mustang Tech
magnapack tip bracket thing
  • Thread starter Thread starter reezy
  • Start date Start date Jul 21, 2004
R
reezy
21
  • Jul 21, 2004
ok here is the deal i installed a magnapack catback on my 03 gt (which sounds SIIIIIIICK by the way!!) but the metal hanger on the tip which allows me to adjust the tip has rattled off my car on the drivers side.. where can i get one of these things? anyone else had this problem?
03gtmustang
923
Northern Va
Jul 21, 2004
  • Jul 21, 2004
Thats weird, have you talked to Magnaflow?
R
reezy
21
  • Jul 21, 2004
nah not yet, i will have to contact them tommorrow..yea i have heard of the tips rattling and *****, but i didnt know that metal hanger would rattle off...now my stang looks ghetto with only one tip
Thundermouse
168
Decatur, GA
Jul 21, 2004
  • Jul 21, 2004
That is wierd. A couple of days after I put my magnapacks on I noticed that one of the tips had moved slightly, so I straighted it and re-tightened its fastener (on the same hanger thing that you're talking about). I have never heard them rattle before. If I were you, I would get up under there and see what else is loose and then go ahead and tighten it down. That catback system is a pretty tight fit, so nothing should be rattling. Maybe you can talk Magnaflow into sending you another tip.
R
reezy
21
  • Jul 21, 2004
the catback fits real nice under the car, its just that the iron rod that holds the tip flush with the bumper just fell off!! GODDAMMIT!i will give them a call tommorrow
C
CottonBurnerz
Banned
May 10, 2003
1,554
Drink and Drive = Teh Lose
Jul 21, 2004
  • Jul 21, 2004
the bushing of the hanger should hold the metal rod.. the little hex nut screw thingy got loose twice but the rod never fell off.. nor did the hex nut..
o.. and i got a rattle one time on driver side rod. I just wrapped the end of the rod with a rubberband and problem solved
W
WickedDropTop
35
San Diego
Jul 22, 2004
  • Jul 22, 2004
Same problem when I had the magna pack, got rid of it for the regular mag cat back, found the set srews at true value added some lock tight, no problems in 12,000 miles, I think the extremely low tone of the magna pack is the culprit
loudog_jon
195
Florida
Jul 22, 2004
  • Jul 22, 2004
i had the same problem, the set screw rattled loose, and while driving to work the metal hanger rattled its way off of my car. i think it was like $15-$20 to get a new hanger from magnaflow, and you can get the set screw at any hardware store for under $1. make sure ,like wickeddroptop said, to get some locktite. i think red is permanent and blue is temporary, depending on if you want to take your tips off to clean them. just go to the magnaflow website, and the should be a customer service number to call, and they will send you the new hanger.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
M
1991 GT cigarette lighter/port not working (horn is working)
  • MartinM
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 30, 2025
MartinM
M
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
