Main bolt ?
  • Thread starter Thread starter cola8d8
  • Start date Start date Oct 26, 2004
C
cola8d8
65
  • Oct 26, 2004
Do you have to use the factory type main bolt (the one with a stud on the end) to hold the oil pump pick up tube? If you use a regular main bolt do you just let the oil pump pick up be held in place by the oil pump?
M
matm347
2,056
  • Oct 26, 2004
It will work, just make sure there isn't much difference in the install location.
On a side note, roll the edge of the pickup while you have it out. It helps only fractionally, but since you have it out...why not?
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Clutch pedal to Quadrant lag
  • Potomus Pete
  • Aug 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
speedmaster new 302 block?
  • rednotch
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2026
rednotch
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
351w aluminum oil pump?
  • Kid wita 5oh
  • Oct 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2025
Mustang5L5
