Maintenance Recipes
apats77
178
Watertown, MA
Its almost time to jack up the ride and do some maintenance!
If you are up to it please post what items you replace and what products you use.
98,000 miles.
Sea Foam (Crankcase, Vacuum line)
NAPA full synthetic 5w30
Fram Tough Guard Oil filter (TG2)
Currently using:
Autolite Platinum Plugs
OEM Wires
K&N Drop in
When I buy a vehicle, I do full maintainence on it. I change spark plugs, engine oil, oil filter, transmission fluid, differential fluid, fuel filter, clean/change air filter, clean MAF, and check the ball joints. If this is the first time for you to do some maintainence on your car, I would suggest all that plus new spark plug wires.
I did all of that ( had to change the diff fluids twice, replaced the differential and went w/ 3.73s then again when one axle failed) when I pulled the old motor.
I was just wondering what products people use
Motorcraft oil
Motorcraft fuel filter
Mobil 1 atf/lucas trans fix in the tranny.
Costal gear oil
Motorcraft tailshaft seal
Timkin pinion seal
Pretty much my last tune up on the car. There is a thread about it one the first or second page here. I had a couple of leaks to fix, and I changed my plugs not long ago. Including hooking up my exhaust it was an all day job.
