Major Problem--NEED HELP!
MustangMatt1966
1,004
Orlando Fl.
Ok, so I got back to college today from my vacation, and i went to roll my window up in the parking lot and its stuck down...i took the pannel off to try and see what the problem is and I cant find anything nor see a problem. The window is in the down position and wont budge to go up..this creates a major problem seeing as I am at school and dont want people to screw with it..i dont have a lot of tools up here, so I put the car cover on it and wanted to post this to see if someone could help me or had an idea...thanks guys...
:Damnit:
10secgoal said:
Tried lifting the bottom of the frame while trying to crank it? May need a little help to get started.
like reaching my hand through the hole to the bottom of the window and pushing upward while cranking???
i tired pushing it up from the bottom and it didnt move at all, but i didnt try cranking while doing it...the think seems like its jamed, i pushed on the crank with all my might and it doesnt budge at all....ughh
67CoupeDriva said:
May be a broken roller lodging things up, or a bad regulator. you may have to apply a little "pressure" to get it raised, or detach it and try to work the mechanism up without the glass. Loads of fun, good luck.
oh great...nothing better than doing that in the parking lot of a school...
Don't push too hard, the materials inside are not heavy duty and can bend/break.
Sounds to me like a roller has jumped off it's track. Visually inspect the scissors for anything out of place.
Sorry, was thinking you had the cover off...right ? I can't remember the exact location of the frame when it's down. But I wanna say there is something to grab onto. But not too hard like Edbert said. Stuff is kinda weak.
no, its not past he window felts, its right in between them level with the door...this makes me mad, because, today, of all days, when i get my window stuck down, it pours for 4 hours, granted i had a car cover on, but it isnt waterproof...so ya, the inside got wet...ugh...
then your regulator must have jammed up or broke
If you don't have a lot of time and need it fixed right away - go to a local glass company and have them take care of it.
Much better than getting it vandalized or stolen because the window is down. Even just imagine a bird going in there...
This is probably not it,
but my passenger side window for some reason tries to push more forward instead of up. I have to pull on the window towards the rear of the car while rolling it up because it will get halfway up and not move anymore. So see if the window has any wiggle to it.
thats a good idea, accept i cant get a good hold of it cuz its down all the way, and i dont have the smallest fingers to get in there and grab it....i have pretty much given up hope of trying to fix it and i think im taking it to the shop on friday, i just hope it stops raining around here.. crapola
