MAKES NO SENSE!!!!!
  • Thread starter Thread starter cherokeetrinity
  • Start date Start date Sep 22, 2009
First Prev 2 of 2
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 23, 2009
#21
  • Sep 23, 2009
  • #21
Everything in this diagram needs to be pluged in. Beside the Canister Purge, EGR( it will run with out). The MAF connector is not listed, but IS needed.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 23, 2009
#22
  • Sep 23, 2009
  • #22
cherokeetrinity said:
i forgot one thing, ...... when i take the firing order and change it to the 154... it will fire up and run REALLY weird!! why would it run on the wrong firing order and not the right one????
Once you get all the sensors plug up.
Make sure the Firing order is correct on the Cap. They go Counter clockwise on the Cap.
C
cherokeetrinity
49
#23
  • Sep 23, 2009
  • #23
when i got this car the motor and tranny was ripped out, so i put it all back together.. it doesnt have a barometric pressure sensor, what is a H.E.G.O sensor?? what do they do?? im new to all this, im just learning and i greatly appreciate everyones help, and liljoe, the pin that is shorter is the #3
C
cherokeetrinity
49
#24
  • Sep 23, 2009
  • #24
theres is also a number of wires on the passenger side fender well with plugs and what not, i have no clue what they are, btw, the whole upper and lower intake is off of an 86 mustang so i imagine that theres going to be a couple things different right??
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 23, 2009
#25
  • Sep 23, 2009
  • #25
Thats the VSS sensor PIN(one of them). Not important right now.
HEGO = 02 sensors.
C
cherokeetrinity
49
#26
  • Sep 23, 2009
  • #26
lil joe, is there another place we can talk, u got yahoo or something?? it would just be a little easier
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 23, 2009
#27
  • Sep 23, 2009
  • #27
PM sent.
C
cherokeetrinity
49
#28
  • Sep 23, 2009
  • #28
huh??
C
cherokeetrinity
49
#29
  • Sep 23, 2009
  • #29
sorry, could you send another pm please, i had a pop up blocker on
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 23, 2009
#30
  • Sep 23, 2009
  • #30
Sent
M
mac7290
28
Phoenix, Arizona
Sep 23, 2009
#31
  • Sep 23, 2009
  • #31
My guess is your timing is off just a little. try lifting the distributer out just enough to turn the rotor, and turn it just enough counter clockwise to move it one gear tooth. That little bit will make it seem like its not firing at all to starting right up. It's happened to me. thought i had it timed right on and it was'nt. worth a try altleast. start simple.
D
defcondaze
48
#32
  • Sep 23, 2009
  • #32
its all beginning to make sense
1987stangman
684
24
#33
  • Sep 23, 2009
  • #33
liljoe07 said:
You did make sure you stabed the Distributor on the Compression stroke right?
Your JUST now asking him this question? That should have been the first question you asked instead of telling him he has a fried ECM...
Noticed no one else has added a answer yet.
1987stangman
684
24
#34
  • Sep 23, 2009
  • #34
The O2's (HEGO's) do NOT have to be pluged in for the engine to "run" but are needed for proper engine control under normal operating conditions. What you need to do is slow down and get at the very least a harness diag. off the internet or a Ford Fuel injection book and study it so that you fully understand what each sensor and wire does and how it connects up. You will prob be here all day with liljoe07 helping you.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 23, 2009
#35
  • Sep 23, 2009
  • #35
Regardless of what you may think you know, Its a Reality that Hooking up the ECM test Port wrong Fries the ECM. But it does depend on what its hooked to. Nothing wrong with making sure the ECM is fine. Even if he got it to fire, and the ECM was screwed, it would have had to been checked.
I even said it would fire, I even said it would run.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 23, 2009
#36
  • Sep 23, 2009
  • #36
The fact that you didnt know about the test port, says alot about your "tinkering with EFI mustangs" The fact that you type like its a text message says alot too, either that or you dont know how to spell " Probably"( I spelled it for you, that way you know what it looks like). Takes alot more than " tinkering" to understand EFI. For instance, if the TPS voltage is through the roof( which can happen from burnt SIGRTN, or Faulty TPS), it shuts the Injectors off( Flood Mode per GUFB). And what do you know, no start, no run.
Thanks try again.:Zip2:
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 23, 2009
#37
  • Sep 23, 2009
  • #37
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 19-Jun-2009 to clarify ignition switch & coil power states.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire with the switch in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire. You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:…
Sorry, the AutoZone wiring diagram links no longer work. You can navigate to the diagrams yourself via AutoZone.com | Repair Info and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
C
cherokeetrinity
49
#38
  • Sep 23, 2009
  • #38
actually its nowhere near beginning to make sense, obviously no one was paying attention to what i said, it was EXACTLY TDC!! i checked it not once, not twice, but four times!. anyhow to make sense of all this...lol i had it in time, PERFECTLY TDC! and then i said **** it, i threw the distributor 180 degrees out, and it ran, it was a little screwed up but it ran, then i took and threw it two teeth out and bam!! it runs like a ****in charm!! and the ONLY sensors i got hooked up are the oil temp, the water temp, the TPS and the idle air controller... now Explain that!!! and incase anyone was wondering if i was wrong about it being 180 degrees out, get this, when i put it ion TDC, take off the valve cover, verify that both valves are closed, and they are, then pop out #1 plug and and see if its at the top ( and it is) then take off the distributor car..... the ****in rotor is NOWHERE NEAR #1 PLUG!!!!!!!! but it runs like a dream! no problems whatsoever, idles smooth, and i can take it out on the road and smolder the tires. that my friends is UNEXPLAINABLE!!
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 23, 2009
#39
  • Sep 23, 2009
  • #39
You could have been at the end of the exhaust stroke. Thats what made you think is was on the Compression stroke. They both look the same( or close to it) when looking at the valves. Plus the Piston will be at TDC also. Its trickery. Thats why you stick your finger or a piece of tissue, and rotate crank till it pops out. Thats the Compression
D
diggy pits
9
ARNOLD MO.
Sep 24, 2009
#40
  • Sep 24, 2009
  • #40
I THOUGHT YOU MIGHT B 180 OUT
First Prev 2 of 2
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
  • dan50
  • Jul 18, 2026
dan50
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
