Making t5 pedal assembly easier??
  • Thread starter Thread starter Kdubslugga
  • Start date Start date May 21, 2006
Kdubslugga
1,515
Akron, OH
May 21, 2006
  • May 21, 2006
I was just wondering if removing the dash would help make pedal install alot easier? Any other tips pointers are welcome for my t5 swap
GearHd6
459
Ashford, CT
May 21, 2006
  • May 21, 2006
Pulling the dash is WAYYYY more work. It can be done buy dropping the column. Takes a little patience and twisting and turning in just the right order and they'll go in. Dont make more work for yourself.
gunmetal5.0
144
Chico, CA
May 21, 2006
  • May 21, 2006
seemed like taking dash off ended up being easier in the long run. that was my experience. i removed the dash of the donor car and it was way easier to remove the pedals, only took maybe 15 minutes to remove the dash, some screws, disconnect some pigtails, e z cheez. installation is easier cuz youve already done it once. take it e z.
Kdubslugga
1,515
Akron, OH
May 21, 2006
  • May 21, 2006
Well the reason i wondered about taking the dash out, was because i have the center console out right now because of getting out the old AOD shifter, and i have to take out the guage cluster to relocate the speedo cable. I dunno it is alot of work but im wondering if its gonna make it easier in the long run
gunmetal5.0
144
Chico, CA
May 21, 2006
  • May 21, 2006
trust me, i did a t5 swap too, its easier to just take out the dash, it really doesnt take that long either. also it helps for hooking up and relocating the speedo cable and clutch cable. have fun
gunmetal5.0
144
Chico, CA
May 21, 2006
  • May 21, 2006
also, take out the drivers seat, its 4 bolts, really helps. =)
GearHd6
459
Ashford, CT
May 21, 2006
  • May 21, 2006
I did the swap also, took me an hour to change out the pedals and hook up the switches by just dropping the column. Like I said, patience is a virtue.
gunmetal5.0
144
Chico, CA
May 21, 2006
  • May 21, 2006
someone grab their stop watch me and gearhd are gonna see which ways easier once n for all
gunmetal5.0
144
Chico, CA
May 21, 2006
  • May 21, 2006
lol patience is a virtue, wasnt that what i was pointing out by taking the time to remove the dash? hmmm
V
v8only
2,378
22
49
May 22, 2006
#10
  • May 22, 2006
  • #10
man you guys go about things the hard way.
man up and use some patience and mechanical skill. It's only 5 bolts that hold that pedal assembly in, and although it doesn't see this way, they're all VERY easy to access. Dropping the dash will take you a lot longer, imo...unless of course you want to replace the heater core while you're in there.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 22, 2006
#11
  • May 22, 2006
  • #11
I was just gonna say that about the H/C
Paully's5.0
495
WI
May 22, 2006
#12
  • May 22, 2006
  • #12
I took the steering column out completely, one more bolt is all, and a couple of wire connections and out it comes. Lots more room to work!
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
Swapping clutch pedal hanger-
  • woodsnake
  • Nov 8, 2026
Classic Mustang Specific Tech Nov 8, 2026
woodsnake
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
