bnickel
So anyone know for sure if i should use a lot of the grease it comes with ot just a little? My wiring harness is brand new (EZ-wiring) so i dont think or know if it has a resistor wire like the factory harness. Should i use a resistor ? Thanks for the link to the Accel module, i ordered than one instead of the mallory unit, saves me $50!
it probably does not have a resistance wire so you would need to use a ballast resistor but double check it just to make sure, some of the aftermarket harnesses can be tricky like that. i prefer the chrysler style because they don't have too much resistance and you can mount them anywhere, even under the dash if you want. the one for a 69 or so 340 cuda should work fine
