Man I screwed up!
  • Thread starter Thread starter 68converted
  • Start date Start date Feb 2, 2006
68converted
772
Colorado
Feb 2, 2006
  • Feb 2, 2006
I screwed up. In my infinite need to be stupid, I picked up a set of Granada spindles that I scoped out at the Pick and Pull and was going to Ebay them. I have a set of Versialles spindles on the car with the Mustang Steve lower ball joint sleeve. Everything would have been fine, but I decided to make everything perfect by switching out the spindles and have a true Granada Set up. In my effort to get the sleeve off, I scratched the hell out of it and it won't come off.
So, now I have a lower control arm that has a fixed ball joint and a scratched up sleeve. What the hell do I do? I don't want to buy a New lower control arm. Please help the stupid.
wild70stang
317
  • Feb 2, 2006
do u mean u "sliced" the sleeve? do u mind posting some pics. Whats wrong with just replacing the sleeve?
68converted
772
Colorado
Feb 2, 2006
  • Feb 2, 2006
The sleeve is frozen to the ball joint and it has a few real deep scratches in it from the pliers. Man that sleeve is real soft metal. I am glad I decided to go to a spindle that does not need it. Anyone have any ideas? The LCA is in real good shape, so replacing it is not what I want to do.
66Runt
680
Feb 2, 2006
  • Feb 2, 2006
die grinder with cut off wheel
Just be careful not to go all the way through the sleave. Then a fat chisel placed in the grove, will "crack" the remaining portion of the sleave with a few good "whacks".
shouldn't take more than 10 minutes this way.
If you don't have a die grinder, you can use a hack-saw to make the cut, just takes a little longer.
Good luck,
Scott
68converted
772
Colorado
Feb 2, 2006
  • Feb 2, 2006
Ok, from stupid to a stroke of genious. I threaded two nuts onto the stud tightened them together, put a wrench on the nut and a vice grip on the sleeve. Twisted right off.
Whoooh.
Thanks all, again. You gotta admit it is a funny situation to be in. This is what I felt like doing-
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
P
Suspension Different height ball joints?
  • pindude80
  • Jun 10, 2024
3K
Fox 5.0 Mustang Tech Jun 12, 2024
limp
