Manifold Glowing....This is New
351wcoupe
1,811
Manhattan, Kansas
After driving the car hard pretty hard and spraying twice 19psi+70shot. I noticed the unported E6 was glowing really bright. The A/F (I know its not a WBO2 but...) was showing one bar in the green. I let it cool down completely. I drove it home easier and it was glowing slightly at the flange and the exhaust side of the turbo. Seems to run fine. What possibilities am I looking at? If it were the cat it would glow at the cat instead, right?
Ray III said:
Ideally you want engines to run a tiny bit lean
since when do you want a car with a power-adder to run lean? :nonono: let alone a car with two power adders? Theres a grey area where your not lean or rich (which is where you want to be) and depending on how dangerous you want to live, you can creep towards the lean area, but running lean = :notnice:
Ray III said:
You are just wasting fuel when you run rich. And I didn't say you want an engine to run LEAN, I mean it should be lean biased but close to stoichiometric air to fuel ratio.
You guys can go debate with Ford powertrain engineers on what a bad idea it is.
Running a car with a power adder, much less 2 power adders lean is a bad idea. I don't have to debate it with Ford engineers, because they designed the 2.3 Turbo's to run rich. If you don't believe me, open up a PE fuel table in PCMX.
