manual and auto computers
LT1 Eatr
20
i bought all the items to perform a mass air conversion, only to find out the night before the swap that i have a automatic computer (part #e9zf-12a650-ca ). my question is can i use this computer on my manual trans 88. thanks guys, mike :shrug:
If it's an A9P it will work with manual or auto. A9L's are strictly manual. I think you can still use them in the auto, but you just won't be able to pull certain codes correctly. Doesn't matter in your case though since you are manual.
Just dont forget to do whatever starter interlock repinning you have to do (you do, dont ya? I think so).
Good luck.
i don't know about the starter interlock on the last post.
it is a a9p computer and i am useing the conversion instructions off the stangnet tech area(enter mass air conversion in google and it is the first page on the list). it seems very detailed but if there is something missing from those instructions, please let me know. thanks for your input guys and any other helpful tips are appreciated. mike
I have used both the A9L and A9P computers interchangeably with a 5 speed without doing anything to the wiring. It's a bolt on, one for one swap. I did not notice a difference in the way the car ran with either computer.
As far as the mass air conversion instructions go, follow the Stangnet directions to a T and you will be in good shape. No worries and no missing or extra wires, the directions have all the wiring documented.
The Lord of Tech has spoken. :hail2:
OOps, after seeing the title and reading the first post, my brain vaporlocked and I thought you were doing a trans swap.
I was thinkin of the stuff with the manual trans puter not having a diode because it sees neutral-status, where an auto puter sees cranking voltage, or whatever the issue can be. My bad.
Nevermind.
thanks
i appeciate your input and i will make sure to keep you posted on any other mishaps i may have with my new found turd. if you need any t5 rebuild or up grade expertise give me a hollar (i rebuild t5's for a hobby).thanks again:hail2:
