Manual boot on auto shifter?
I tried to do it and a stock Fox boot won't really fit well.
It will fit fine in Park or revese, but if you pull the shifter down into D or 1 (or 2 and 1 for you a4ld guys) it would pull the boot off or bind up.
Even the 5-spd plate didn't want to fit around the Auto shifter right.
mine worker with the stock T5 boot. and i removed the plastic shifter thing that says P R OD D 2 1 and it fit good, i all so used the 5spd shifter bezel too .and i think i put the boot on backwards so i could get in to 1st
Got any pics?
I worked at it for a while but still couldn't get it to work out good. Maybe there is a physical size difference between an AOD and A4LD shifter unit?? That's where my prob was, the 5-spd plate was hitting the unit.
