Manual shifting an aod
Install a manual valve body and get a shift kit/ decent clutch packs and you'll love it. My AOD shifts so hard it feels like someones rear ending the car. then you can get a nice TCI or B&M hammer shifter. I guarantee you hitting a ratchet shifter is faster than a person shifting using their hand and leg. There will be no lag full engagement with every shift. My AOD Manual valve body trans was the best bang for buck mod i did. Either way make sure you get a stacked plate trans cooler.
Performance Automatic
Chris
Ever driven a "race" manual transmission?
I'm not debating it, as a race prepped auto is one bada$$ toy, but after having driven a handful of race manual cars, there is basically no lag and full engagement with every shift. Interesting feeling the first time you shift a T5 (not a stocker thats for sure) without hitting the clutch. :D
you cannot shift faster than a race prepped auto trans period. A machine is faster than you. Manual trans has to go from one gear then thru neutral into the next gear. You cant shift as fast as an auto. Period. The auto trans does require horsepower to run it though, there is some loss of hp when ussing an automatcc.
You must not spend a lot of time at the track....or for that matter ever heard of power shifting? I've seen man beat machine plenty of times...and I'm regularly am able to do it myself. Well built auto cars are faster than most....but not all. A full blown race set up is one thing, but your average street car is entirely another.
Using your own "moving parts" logic, let's compare the two and count the steps....
Manual = gear/neutral/gear
Auto = gear/torque converter/pump/cervo's/valve body/gear set/clutch pack/gear
at the track.....
View: http://youtu.be/1cC-Nyg7ZHE
...or on the street.....
View: http://youtu.be/6JEv6Ycyx6s
I did it for years on my AOD. I didn't do it daily, but at the track, and a few times on the street I would do the 1-D-1 shuffle.
never had an issue other than having an AOD. Glad i swapped to a stick though
doing the 1-d-1 dance is rubbish. better to get a reprogrammed valve body from silver fox or lentech that will allow you to hold second gear without the possibility of damaging the transmission with the constant 1-d-1 dance. the other nice thing is that lentech and silver fox both have od lock outs.
Reactions: 95Vert383AOD
