Okay, so I'm going to have to do away with the slobbery ol' power steering setup on the Notch pretty soon, as I'm leaking out more P/S fluid while it sits during the week than I actually use up while driving it, and it's making my driveway look like a dinosaur took a leak on it. Soooooo, the plan is to replace the power rack with a manual rack/pinion and somehow route the belt to only run the alt, water pump, and smog pump. Thus, my bunch o' questions are as follows:
1. Other than a manual rack and manual steering shaft, what other added goodies do I need to do the swap? (I'm assuming the tie rod ends are the same between the P/S and manual racks, right?)
2. As long as it isn't mangled during the removal, will the rag joint from my P/S steering shaft work with the manual rack/shaft?
3. HOW the HECK do I route the belt to include the water pump, alternator, and smog pump (no A/C) without having to also install a standard-rotation water pump and a ribbed water pump pulley? I mean, do I need to buy one of those funky tension rod things, or just flip the stock tensioner, or ... or ... something?
4. Anyone know exactly what belt size to use for a water pump/alt/smog setup?
5. I know the steering effort will be a lot tougher in parking lots and low speeds, but will it be ungodly hard to turn if I were to be running, say, 245/50/R16 tires front/back? (Or will I pretty much have to switch to running skinnies or nothing wider than 225's up front?)
I know a lot of folk have done the swap, but I dunno if anyone out there has also kept their smog pump in place - everyone usually seems to delete the P/S at the same time as the smog pump and the A/C. I still have my UPR A/C delete pulley, which I suppose I could use as an idler pulley if I absolutely had to, but the bearing in that thing is wobbly and I can't seem to find an exact-sized replacement to fit inside of it that doesn't just wiggle and slop all over the darned place (which I fear will result in the thing throwing/eating a belt at high RPM's).
Mucho thanks in advance!
