Manually Engaging A/C Compressor
  • Thread starter Thread starter Guero
  • Start date Start date Jun 10, 2008
Guero
2,148
Jun 10, 2008
  • Jun 10, 2008
How do you Manually Engage the A/C Compressor on a 91 GT?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jun 10, 2008
  • Jun 10, 2008
Turn the switch on and jumper the harness for the low pressure sensor on the accumulator.
Guero
2,148
Jun 11, 2008
  • Jun 11, 2008
You mean turn the AC on right? How do u jump the sensor?
BlownFiveLiter
18
108
Chicagoland
Jun 11, 2008
  • Jun 11, 2008
You actually want to jump the harness. Unplug it from the sensor and put a piece of wire across the connector. Don't do it if it's an empty system, or you'll fry the compressor.
Guero
2,148
Jun 11, 2008
  • Jun 11, 2008
Well I tried and its not spinning!
HISSIN50
34
129
Jun 11, 2008
  • Jun 11, 2008
Guero, if your compressor won't engage for no apparent reason, check the WOT relay and its wiring socket. They are on the passenger fender kinda under the MAF. The wiring is very susceptible to getting baked and causing an open circuit or other issues. Sometimes just moving the relay around in your hand causes the AC to kick on.
Redoing the wiring or splicing in a new socket and relay are the common solutions if this is the issue.
An issue at this junction will cause jumping of the LPCS that Matt talked about to not work.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 11, 2008
  • Jun 11, 2008
Get out your voltmeter and check for 12 volts at the low pressure cutout switch that you were told to jumper. No 12 volts, keep on looking...
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
Guero
2,148
Jun 11, 2008
  • Jun 11, 2008
Thanks for all your help!
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
Engine A/C QUESTION
  • Mindseye007
  • Jun 5, 2025
  • 2 3 4
3K
Fox 5.0 Mustang Tech Jun 22, 2026
nicholase
W
a/c compressors i d
  • waxman
  • Jan 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Brakes are engaged while driving
  • stevetbright
  • May 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 31, 2026
stevetbright
T
A/C Compressor Reliability with Supercharger Setup – Need Advice
  • ThotTrap
  • Aug 29, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 29, 2025
