Map Sensor Question?
  • Thread starter Thread starter MY 85 GT
  • Start date Start date Feb 25, 2014
MY 85 GT
1,852
208
104
New Jersey
Feb 25, 2014
  • Feb 25, 2014
I was wondering something...my map sensor is from a Speed density car but it is now a MAF car..i looked up the part number from 87 to 89 and there different part numbers would that hurt anything?
madspeed
Colonel Mustard
1,332
204
a van down by the river
Feb 25, 2014
  • Feb 25, 2014
nah, its the same thing
madspeed
Colonel Mustard
1,332
204
Feb 25, 2014
  • Feb 25, 2014
a little clarificaion
Speed Density uses the vacuum port. That's the MAP part of the sensor. In Speed Density setups, when the Key is turned on, its takes a Barometric reading, and updates the Barometric under certain conditions. Like under a load when vacuum is low. When its not taking a Baro reading, its doing the MAP calculations based on Manifold Pressure.
MY 85 GT
1,852
208
104
New Jersey
Feb 25, 2014
  • Feb 25, 2014
you sure why are the part numbers different then when you look one up for a SD car or one for a MAF car....lol
MY 85 GT
1,852
208
104
New Jersey
Feb 25, 2014
  • Feb 25, 2014
I know mine doesn't have any vac to it being it is MAF now but wouldn't the inside electric part be different in some way ??? if you know what I mean..
madspeed
Colonel Mustard
1,332
204
Feb 25, 2014
  • Feb 25, 2014
bap and map sensors are the same! the only reason ford changed part numbers is because of the hose deturent (cap) that was put on the hose fitting. On the early cars if you pull the lable off it has the old bap part number on them !
MY 85 GT
1,852
208
104
New Jersey
Feb 25, 2014
  • Feb 25, 2014
OK COOL..just was doing some reading and saw someone say there were different...
madspeed
Colonel Mustard
1,332
204
Feb 25, 2014
  • Feb 25, 2014
good technical read here
http://sbftech.com/index.php?topic=19336.0
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,081
224
Massachusetts
Feb 26, 2014
  • Feb 26, 2014
You can use your MAP sensor with the vac line removed as a BAP sensor. It should run fine.
If part ever fails, i'd replace it with an 1989+ BAP sensor
Onefine88
Previously 89SSC18
1,422
796
154
Feb 26, 2014
#10
  • Feb 26, 2014
  • #10
This! I converted my car to MAF last summer when I added the supercharger. I removed the vacuum line.
It runs great.
MY 85 GT
1,852
208
104
New Jersey
Feb 26, 2014
#11
  • Feb 26, 2014
  • #11
Ok guys thanks just was thinking that last nite was wondering if it would be ok to leave it that way...
88LX5.Oh
1,442
205
94
Arkansas
Feb 26, 2014
#12
  • Feb 26, 2014
  • #12
It it wasn't ok, then hundreds of people, myself included, would be driving around with half assed MAF conversions.
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,081
224
Massachusetts
Feb 26, 2014
#13
  • Feb 26, 2014
  • #13
Some do considering a lot don't wire up the VSS and fuel pump connections.
Reactions: 88LX5.Oh
88LX5.Oh
1,442
205
94
Arkansas
Feb 26, 2014
#14
  • Feb 26, 2014
  • #14
You do have a point there. But thankfully I was smart enough to go ahead and do these steps lol
M
Map sensor
  • miser143
  • Aug 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
AeroCoupe
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
