I recently established that my 2,800 cfm electric fan is not doing a very good job at keeping the Stroker cool. I ordered a Mark VIII fan and I am planning the wiring before starting the install. My research has me conflicted. The install "How To" write ups for the Mark VIII fan I came across recommend using a 30 amp fuse and 30 amp relay. However, I also found that these fans use around 80-90 amps when starting up.
Should I use an 80 amp relay with a 100 amp circuit breaker to maintain that high current?
My other question is will my Hayden thermal control switch handle that amount of current?
This is the switch I bought...
Hayden Automotive 3653 - Hayden Electric Fan Controls - Overview - SummitRacing.com
