Markin the dipstick...
  • Thread starter Thread starter NOSNotch
  • Start date Start date Sep 3, 2004
NOSNotch
577
South Jersey
Sep 3, 2004
  • Sep 3, 2004
i've gotta canton 7qt pan on my new 306, i gotta mark the dipstick for full but just wanna make sure i got the right idea first. Figure I'd put 7qts in it and mark the stick before starting it. Is this the way to do it or am i missin somethin here? Thanks for any help here guys
Kevin
hemi_fan
279
Ontario, Canada
Sep 3, 2004
  • Sep 3, 2004
probably doesnt matter if u start it, as long as you do the same thing every time (ie measure after started, or before)... but im not a pro... so someone else mite have a better solution.
HISSIN50
34
129
Sep 4, 2004
  • Sep 4, 2004
ive always wondered about this. so ill blabber and bump you off the second page.
i would figure the stock pan oil level (absolute level - or level of oil below the crankline) would be the same with any pan (you fill it as much as you can, while keeping the oil out of the crank reciprocating mass. so would the full mark still not work (ie keep filling till the dipstick reads full).
otherwise, i would contact the vendor and ask to be sure. or figure out the oil level on the old pan, where it was full. then figure out how much you can fill the new sump to achieve the same level from the crankline.
sorry - this does not make sense.
oh yeah, i prefer to check oil level on a cold motor (ie sat overnight). so unless your oil filter is dry (you just changed it and have not started it), you could use this method . i dont know the 'best', most perfect way to check the level - warm motor after sitting for a few minutes (like most sportbikes, per the owners manual) or after overnight.
good luck.
T
TheUser
1,859
Springfield, MO
Sep 4, 2004
  • Sep 4, 2004
I've heard the best way to check the oil is after it's sat so that the oil all runs back down to the pan. I'd mark the dipstick before driving after a change, but let it sit an hour or two to let it drain. The stock dipsticks are notoriously off, so it might be a good idea to mark the dipstick w/ or w/o a new pan.
NOSNotch
577
South Jersey
Sep 4, 2004
  • Sep 4, 2004
well i cant go off the full line of the dipstick b/c it's a universal stick for canton pans and it's different between motors i'm assumin. since it's advertised as a 7qt pan thats why i was thinkin i could put 7qts in and mark the stick. Thanks guys
Kevin
Fox 351 dipstick showing overfull?
  • 387lx
  • Feb 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 9, 2026
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Drivetrain Why does my AOD make a 'whirrring sound' when in gear?
  • evintho
  • Feb 7, 2025
Fox 5.0 Mustang Tech Feb 15, 2025
evintho
Engine Obstinate Pilot Bearing removal
  • FastDriver
  • Feb 12, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 22, 2026
manicmechanic007
Paint and Body Rotten moon roof trim
  • Teen'93stang5.0
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 15, 2026
Teen'93stang5.0
