mass air conv.
May 9, 2011
151
Ne
ok i over looked my mass air conv because i have a code 95 witch is related to the wires not running for the fuel pump relay and the vss. im having a problem locating the vss 8 pin plug. i looked behind the d/s kick panel and i have a 8 pin connector but it mainly has pink wires coming out of it non like the connector pic here in step 6.
Mustang Mass Air Conversion «
help in finding this connector so i can route the wires would be nice.
The 95 code won't cause problems in the car's performance.
What color are the wire/stripes on the driver's side kick panel connector?
If you did a add on MAF harness and a re-pin of the old computer harness, install a pin/wire in position 19 of the computer wiring harness connector. Then run the wire to the fuel pump relay pink/black wire.
attachment.php
i found the wires i need to connect to on the cruise control box under the steering wheel area. plus where do you get pins to add to the computer. junkyards willnt let me cut wiring harnesses. i did find some thing that looked like the pins at the auto parts store, so im going to try that.
