Mass air conversion questions???
  • Thread starter Thread starter JMCtheBull
  • Start date Start date Jun 24, 2006
J
JMCtheBull
  • Jun 24, 2006
I have a 88' LX with a 5speed. It has speed density. How much of a difference would it make if I converted to mass air???? What is a good price to pay new/ used? Should I try to get a specific size mass air meter????Thanx, Joe
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Jun 24, 2006
  • Jun 24, 2006
there is only an advantage to the swap when the modifications leave you with a car that is becoming a problem. The problems are most often the result of a cam change that doesn't provide the vac readings the computer needs to determine operating perameters. Head/intake/exhaust...near all boltons will work well with SD. There are cams that will provide the info the computer needs to operate well under SD also. SD cars have even been known to run quicker than MAF cars, not much, not always..but sometimes. Basically what I'm saying is you don't need the switch untill times comes that it's required...I converted to accomdate the engine I was installing otherwise I'd still run SD.
sn9550
1,184
Charles Town, WV
Jun 25, 2006
  • Jun 25, 2006
The only difference it made for me was idle quality. SD cars tend to hunt for idle some times. You can get an IST wire kit, MAF calibrated for your injectors, and an A9L EEC. Check ebay for parts.
_jb_
808
Michigan, Berrien County
Jun 25, 2006
  • Jun 25, 2006
Yep, my car idled strange with SD no matter what I did. When I switched over to MAF it cured the problems.
If you plan on doing more than boltons in the future, you may want to switch to MAF.
M
Mendez33
15
  • Jun 25, 2006
I'am going to switch my 87' notchback into mass air. I heard you get all around better drivability(better idle, better gas mileage, etc.). Is this not true?
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Jun 25, 2006
  • Jun 25, 2006
not true for me at all...you shouldn't have any 'issues' as is...car if maintained should run as well as it did new. If conversion to mass air helps anything out then it's just bandaiding a problem rather than fixing it. A well tuned car will perform and get as good milage as it did new.
Stroked88
42
Jun 25, 2006
  • Jun 25, 2006
My '88 felt faster and idled better after the switch. I went right to a C&L 76mm meter after the upgrade. The stock meter is one restrictive SOB.
How to convert Speed Density to Mass air - Complete walk thru!
  • TTSaleen
  • Sep 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
TTSaleen
Z
Engine New head for ‘88 mass air converted foxbody
  • zahirayunus
  • Dec 13, 2024
Fox 5.0 Mustang Tech Dec 13, 2024
zahirayunus
Z
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
1987 Mustang GT Mass Air Conversion Help
  • mustangmike6996
  • Jan 1, 2025
2K
Fox 5.0 Mustang Tech Feb 4, 2025
mustangmike6996
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
