mass air efi harness?
1bad67sbf
674
N. VA
i seen in 92.5 the efi harness changed with a fuel relay, will i be ok to get one from any mass air setup and use or do i need to stick to the 92 and mine is a 6/92 date so what side does it fall on? i am starting from nothing so none of the stuff under the hood is stock, it is oem just from different years.
i have nothing for the efi harness so help me understand, it has 3 parts to the efi harness? computer to 10 pin, 10 pin to injector, the the injector harness itself? i have a a9l ecu if that matters. if i get a whole harness from a non 92 will it work since im not interchanging year parts?
Here is the injector harness. It has the 10 pin connectors that plug into the main engine harness. This part is the same for all 86-93 mustangs. The engine harness is year specific. so get that from a compatible year. If you need an injector harness send me a pm.
