Mass air question
If no one else finds it before I get home from work, I can post some info on the MAS (the black electronics box).
You can even use some from the Taurus.
Can't remember the specifics though.
jason
trueblue01 said:
Please do. I need to find out what cars i can get one from.
Sorry for the delay.
Check out this site, they list numerous MAS sensors by application and part #.
http://rothfam.com/svo/reference/maf_part_number.html
Basically if it says F1Z on the top, it will work. This is assuming the MAS is going in a stock 5.0 HO MAF tube (55mm).
trueblue01 said:
Someone else needs my meter to put on his car till his pro-m comes back from being calibrated.
A word of caution though...
If this person does not have 19lb injectors, then all this work will be worth spit. The stock MAF/MAS will not work well with larger injectors.
Hope you find one quick,
jason
Thanks for the info. He has 24lb injectors now with a pro-m mass air. His car is totaly stock exept for that and mufflers. I'm putting my 19's in his car and taking his 24's. After my h/c/i swap i think i need to upgrade.
jason
