roworld Member Feb 12, 2004 105 0 17 baltimore md Sep 30, 2009 #1 Sep 30, 2009 #1 I just got a mass air off a lincoln continental, its huge has anyone used one on their foxbody. I don't know what size it is or for what size injectors. Posted via Mobile Device
vristang 15 Year Member Mar 31, 2005 4,933 101 124 Seattle Sep 30, 2009 #2 Sep 30, 2009 #2 Provide part numbers... Measure the ID, and post a pic of the housing...
tannerc91gt This last 25% is foreign territory at this point Founding Member Nov 29, 1999 4,392 2,967 234 Indiana Sep 30, 2009 #3 Sep 30, 2009 #3 I'd look up the stats on the car. Wouldn't recommend using it if you have no idea what it's calibrated for or what size it is, so check that out first
roworld Member Feb 12, 2004 105 0 17 baltimore md Sep 30, 2009 #4 Sep 30, 2009 #4 front side is 3 1/4" wide and flange side is 3 1/2" wide. The p/n on the meter is f50f-12b579-aa afh80-01a Attachments big mass air.webp 28.8 KB · Views: 286 mass air.webp 23.1 KB · Views: 185
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,271 17,959 224 Massachusetts Sep 30, 2009 #5 Sep 30, 2009 #5 Can't use it...at least the electronics portion. I dunno about the housing with Fox electronics bolted on. The MAF's you can use are the following 1995-94 Mustang 3.8L F2VF-12B579-A2A, 1994-92 Crown Victoria 4.6L F2VF-12B579-A2A, 1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A, 1994-92 Town Car 4.6L F2VF-12B579-A2A, 1994-92 Grand Marquis 4.6L F2VF-12B579-A2A, Click to expand... http://www.stangnet.com/mustang-forums/616246-94-95-maf-install-completed-2.html
vristang 15 Year Member Mar 31, 2005 4,933 101 124 Seattle Sep 30, 2009 #6 Sep 30, 2009 #6 afh80 means 80mm housing. As already said... it isn't compatible with the stock ecu. Only way to make it work is by using a programmable chip, like Moates QuarterHorse.
M maritimer95gt New Member Mar 3, 2010 2 0 0 Mar 3, 2010 #7 Mar 3, 2010 #7 I have the same MAF. Just bought it a little while ago. I've got a 95 Gt and I'm damn sure that the MAF is stock calibrated for 24# injectors.
vristang 15 Year Member Mar 31, 2005 4,933 101 124 Seattle Mar 3, 2010 #8 Mar 3, 2010 #8 maritimer95gt said: I have the same MAF. Just bought it a little while ago. I've got a 95 Gt and I'm damn sure that the MAF is stock calibrated for 24# injectors. Click to expand... There is not one single Ford MAF meter that is calibrated to an injector size. Ford calibrated their meters to the ecu they would be used with. Only the aftermarket meters are cal'd for injector AND ecu...
